Hi All,
I'm new here, having just today bought a lovely pair of Beolab 18 (Maple Frets...), and a 'Moment'. I have the speakers here, but must wait a week or two for the 'Moment' to arrive. I no longer have any other B&O equipment, but I do have various Audio and AV Amps with CD players, turntables, iPods/iPads, Airport Expresses etc, and many cables collected over the years.
Although the speakers will be used wirelessly with the 'Moment' when it eventually arrives, I was wondering if there was any way that I could use what I have in the meantime via the phono-plugs on the Beolab 18?
For example, I have an old Cambridge Audio A1 amp/CD combo - could I just take a phono plug-terminated cable out of the Amp's speaker connectors into the 18's to play some CDs?... Or should I just wait for the 'Moment' to come! I'm aware that a little knowledge is a dangerous thing, and I really don't want to blow my new 'babies' through impatience/ignorance...
With Regards,
Any source with a volume control will be fine, when i had my beolab 17s i ran them via rca cable.
I set one speaker to left and the other to right via the switch on the speakers. I then connected them to the source I was using them with and when they detected a signal they switched on.
Beoplay A2
Thank you Markiedee,
I'm sorry if I was mixing up my terminologies re. phono plugs/RCA cable; I'm a little rusty with my cabling names, but I know exactly what you mean. You've given me some confidence to give it a try over the next day or so...
Regards.
Hi Lee,
Thanks for the advice; I've was trying to get my head around the idea of plugging one amplifier into what is essentially another amplifier, but just didn't know/couldn't remember enough about which outputs on the A1 were 'line-level'.
Luckily I have a stereo jack with 2 x phono available, so I'll try your suggestion with the Airport Express - that should do me until my 'Moment' arrives...
Kind Regards.
