Hello there,
My current situation : Room 8 x 6 meter, 3,5 meter high. Hard stone floor. In front BV-11 with one each side 2 x Beolab 18 and on left side 1 x Beolab 11. In the back (8 meter) again 2 x Beolab 18.
On the low volume I am missing some "deep" sound, and on full it's like " boom-boom-boom" sound... if you know what I mean.
Don't have the budget for Beolab 5, but was wondering is upgrading to Beolab 19 would make some difference, with some more "body" in the sound at low, and a more "full" sound on loud...?
Anyone can tell me some of there ideas on this ?
I'm curious. Do you find that the BeoLab 11 makes any difference at all with the BeoLab 18? I've found that in my bedroom setup that the BeoLab 11 improves the sound of the BeoLab 6000s and BeoLab 4000s. I've wondered, however, if it makes any improvement at all for any of the speakers above the BeoLab 6000 or BeoLab 4000 range.
Could you borrow a BL19 maybe?
I can imagine the Beolab 11 being too small and too low-end in combination with your 4 beautiful Beolab 18's. So I would suspect the Beolab 19 to be a good upgrade but I haven't heard the combination in real life. Is the boom boom gone when you leave the Beolab 11 completely out?
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
I have this setup in my livingroom (BL18+19), about the same size..
And the sound is wonderful, very clear and a nice deep sound from the 19's.
You won't regret it!
I second what Normann says. I have this combination and I wouldn't be without my 19 now. I think it looks great with the 18's as well.
Aussie Michael:That's another reason why I went with the BL19
Michael, 2 weeks nail biting before it arrives. Correct?
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
I will ask if we can borrow one for testing. May I ask you if the 19 can act as a deeper sound on lower volume ?
Chris:Michael, 2 weeks nail biting before it arrives. Correct? " Believe nothing you read and only half of what you see, let your ears tell you the truth. "
what is the part, would you know? The only problem I have had is with power cord contacts don't have a great fit, and lose connectivity at times...
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
Aussie Michael:It's gonna push back till April 21 delivery because of an issue with the bL 19s they found a part that could be great over time so they have pushed mine back to ensure its the new stock.
Could "be great" over time? I'm sensing autocorrect at work!
Jeff
...and what was it, that was 'autocorrected'?
The sentence did not make any sense to me either ----- other than that Ausie Michael now has to wait...for some reason
Jeff:Could "be great" over time? I'm sensing autocorrect at work! Jeff Beovirus victim, it's gotten to be too much to list!
