A little question to the beoworld members
I have beosystem 3 mark 4.
is it possible to update its software so it can be decode Dolby Atmos Formate 7.1.4.?
currently its only support Dts H d 7.1.
Thank you
You don´t have Mark 4, because it does not exist. The last Beosystem 3 version is a Mark 3 with 3D-capability. This system support Dolby Digital 7.1 and DTS 7.1 and multichannel PCM 7.1. It does not support Dolby True HD and DTS-masteraudiio decoding. And you can not upgrade the system to support Dolby Atmos.
The newer Beosystem 4, support exactly the same codecs as the former Beosystem 3.
RegardsMartin
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
