I've got a new Beoplay v1 tv with a new xbox, but it runs very sluggishly. The xbox runs fine through the Sony Bravia tv, but it's very unresponsive on the Beoplay, around half a second to respond to any movement of the sticks. Has anyone else experienced this or found a solution? Thanks!
On the HDTV BeoPlay V1 Review it 's written
Although the BeoPlay V1 has a dedicated Gaming mode, which optimizes the performance and reduces the lag while gaming. The lag is still very much present. In normal “Adaptive” mode, the lag is very high at 267ms, while changing into the dedicated gaming mode reduces the lag to 167ms.
This lag is unusually high, as some HDTVs have lag around 20ms or so. As well as setting to the gaming mode, I also turned off all available image improvement options such as image rudder removal and even the light sensor, but 167ms was as fast as I could get it.
I’m sure B&O and most uses won’t be too concerned by this, as I’m sure their target market is less gamer, and more home theater enthusiast.
Maybe this could be the reason ?
Thanks for this - switched to the gaming mode which has helped a lot - certainly workable - thanks for your help :-)
Thanks for the thanks ;but credits goes to the - excellent - HDTV review :)
B&O have now logged this as an issue and there may be a software update in time. This is good as i've had to give up with it and now have the reliable Sony Bravia set up behind the sofa for games nights... will see how this progresses as the Beoplay v1 would be no use for gaming without it.
Lovely for films though...
What are your thoughts on this now? Have you been able to play games properly in game mode on your V1?
