Hi Folks,
My father made some cleaning of his antic and discover some wonders...
Beosystem 7000 white :
Beosystem 7000 black :
Beolink 7000 :
Beolink 5000 (new, remove from box)
http://s1302.photobucket.com/user/sergi000/library/BO?sort=3&page=1
The 2 beosystem are working without problem, I try radio and play a CD, no worries. They are clean, a little bit of dust, but not too much because they were under a protection.
The Beolink 7000 start, incline without problem. The beolink 5000 work also without problem. I Did not test them with the beosystem because I found them after testing the beosystem... :) nice attic !
I live in Paris, France. I can send anywhere in the world but that will need a good packaging. It is not a problem, but that won't be cheap for the systems... Estimation between 50-100usd.
I won't part the systems, my goal is to get rid of them.
Serge
Including in the white setup is also a subwoofer in white.
Pricey to send, but it is a complete setup :)
Nice decks, I used to have a Sims Staab and I just found an old Sims Pharaoh in my parent's garage!
x:________________________
sergi0: Beolink 5000 (new, remove from box) 150 usd
I am interessted in Beolink 5000 if it is realy new, woks fine and does not have any bad pixels.
Please let me know, would would be your price for remote incl. shipping costs to Austria/Vienna (in Euro, please).
Thank you.
Theomaster
Vintage Bang & Olufsen
you have pics of it ? That could interests me :)
