I am in the process of restoration a set of RL 1000. It is the white/light grey combination. It is the light grey frets I am having trouble finding. Can anyone point me in a direction, where I can buy the right color? Second question is what do you guys use to replace the plastic “strips”, that goes around the speaker? Any help are very much appreciated.
/R2D2
you can look here for the frets and here for the strips.
Regards
Vintage Bang & Olufsen
