Hello,
i can not figure out how to remove the covers of my Penta speakers; already viewed this Thread
http://archivedarchivedforum2.beoworld.org/forums/t/12306.aspx
still i can not feel that something "looses" or gets pushed back when i push onto the gaps on the side of the speaker.
Does anyone know a video in which it is visible or might make one ?
nice, thank you
If you do, please could share on here as I have tried following that thread and cannot get mine off. I was too worried to pull too hard and break something.
Stoobie
Nice job, good video :)
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
leosgonewild: Tell me if I need to make a better one during daylight
The video is great and shows exactly what to do.
Stoobietoo: The video is great and shows exactly what to do. Thanks Stoobie
nothing to add, thanks alot
Mine still won't come off...
I have the feeling i'd have to squeeze so hard it would break :(
Did they change it with models or something? (mine are mark III)
Milo: Mine still won't come off... I have the feeling i'd have to squeeze so hard it would break :( Did they change it with models or something? (mine are mark III)
Hi Milo
No changes with Penta MkIII, Mine are MkIII and it works the way shown in the video... although the first time I removed the frets of mine I was amazed about the amount of pressure/force I had to excercise to get the clips off and also was afraid of breaking something but all went well.
So keep trying, be brave and push harder
Foxtrott
"The first thing we do, let's kill all the lawyers."
William Shakespeare, Henry VI, Part 2, Act 4
