Beolab 4 wall mounts
This post has 2 Replies | 2 Followers
Chris Townsend
Qatar
Posts 3,531
Chris Townsend Posted: Fri, Mar 20 2015 7:21 PM
Just a quick one, can the Beolab 4's be rotated on their wall stands?
Ie point in the direction you want!
madskp
Denmark
Posts 321
madskp replied on Fri, Mar 20 2015 8:29 PM
If you use the mounting holes the answer is no because the are placed in a isosceles triangle.
However i think it would be possible to drill some new mounting holes and place a couple of spacers between the bracket and the speaker.
Chris Townsend
Qatar
Posts 3,531
Thanks, just a thought Yes - thumbs up
Page 1 of 1 (3 items) | RSS
