G'day,
Has anyone seen this device or used it, or even bought it? It connects to speakers using WISA, and it has Blu Ray, SACD, etc
I wonder if Sharp will have any collaboration with B&O
Thanks in advance
Michael.
Bang & Olufsen have not created WiSA.
WiSA is an association of many electronics companies which use Wireless Sound Audio technologies.
http://wisaassociation.tumblr.com/post/107353126233/new-members-wisa-certified-products-introduced
Sharp was one of the first companies to launch a WiSA compatible receiver/player.
But it takes a company like B&O to reveal the potential of the WiSA technology.
One that has experience with receivers (or rather 'pre-pro's') as well as with (active) speakers.
Klipsch has recently launched a WiSA speaker system. They use a hub as the heart of the setup.
'The “brain” of the wireless Klipsch system is the RP-HUB1 smart distribution hub that allows for simple connection to up to 4 HDMI® equipped devices, digital optical, analog and Bluetooth® wireless technology, including the high resolution aptX® codec. The hub processes multi-channel inputs and distributes them wirelessly with transmission of up to 24 bit/96kHz. The system is also expandable over time, allowing configurations from 2.0 all the way to 7.2 channels.'
I am not sure, if one can combine the Klipsch set with the Sharp Universal Player, since the Klipsch set uses 'it's own' hub.
Would be interesting to read a review of these products.
