Luckily we have have the Archived Forum, so I just found a part of the answer to my question.
If I have the Beolink Passive connected via the powerlink cable as a simple amplifier for passive speakers, is it on stand by when I don't listen any music or is it in a permanent work ?
Answer, when you switch to standby, the passive amplifier switches to standby as well, subject to a correctly wired powerlink socket.
Would it be possible to connect a Beosound Essence to the passive amplifier in the same way, anybody tried this combination? If so, what are the experiences.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
I did not try that combination, but it would work just as any other PL connection.
For the BeoLink Passive (as amp) you will need a fully wired PL cable - in this case
with the item number: 6271225 (for the 5 m version) 6271226 (for the 10 m version)
available at your B&O dealer.
I am sure Steve at Sounds Heavenly would help out with any other length.
MM, thanks for your excellent and fast reply.
But actually I was looking for an answer if the passive switches also correctly to standby with an Essence connected to it by a right powerlink cable. Probably its a yes, but I was looking for a confirmation. I'm not expecting many answers, most likely not many people are using such a combination.
