Beogram 3000 type 5228 Dust Cover compatibility query
ChromaticMind
Posts 8
ChromaticMind Posted: Tue, Mar 24 2015 3:06 PM
Hey guys,
I have a Beogram 3000 type 5228 and recently the dust cover broke :(. The hinge seems ok but the acrylic part that goes into the hinge snapped off under its own weight.
I have been looking online for a dust cover but its hard to find one on its own.
Does anyone know if there are other Beogram models that have dust covers that fit the 3000 type 5228? Even one without a hinge is ok like the Beogram 1200 series.
Your help is much appreciated!
Thanks in advance :)
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Mar 24 2015 10:05 PM
Beogram 2000 (the version in design like your 3000) will also fit, though the hinge block will be black rather than eloxated aluminum.
Dustcovers from Beogram 1200, 1202 and 1203 will also fit.
BTW so will the dustcovers from Beocord 1200 and 1600.
ChromaticMind
Posts 8
Thank you Martin!
I shall broaden my search now and hopefully I can get a good dust cover soon.
Thanks again :)
Page 1 of 1 (3 items) | RSS
