How to connect Beolab 7.1 to non b&o TV
This post has 4 Replies | 0 Followers
Kokane81
Posts 19
Kokane81 Posted: Tue, Mar 24 2015 8:08 PM
hi
Im would like to try and use my old Beolab 7.1 with my Panasonic TV, I'm guessing I'm going to have to come out of the headphone socket but how do I get the speaker to switch on?.
regards
chris
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Wed, Mar 25 2015 1:58 AM
You'll find the right cable here:
http://www.soundsheavenly.com/
x:________________________
Aussie Michael
Melbourne, AU
Posts 3,730
Just check with the Panasonic TV that when you plug in headphones (as a test) that you can select headphones as a source and use your remote for the volume.
With my old panasonic you could... it's rare that you can do that .
Cheers
Kokane81
Posts 19
Kokane81 replied on Fri, Mar 27 2015 11:21 AM
Update, sorted it myself.
got a 3.5mm jack connected to a mk3 powerlink then took a old usb cable plugged into TV and used the 5v off that.
so now I have switching on off of speaker when the TV turns on and off.
Cheap as chips!!
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Mar 27 2015 12:50 PM
Good solution, well done!
//Bo.
A long list...
Page 1 of 1 (5 items) | RSS
