Essence remote
This post has 12 Replies | 2 Followers
benoit
France
Posts 646
benoit Posted: Wed, Mar 25 2015 5:44 PM
Hello, is it possible to use an Essence remote to adjust the volume from a Beoplay A2 or Beolit 15 or even from a Mac via Bluetooth?
chris8535
Posts 5
chris8535 replied on Wed, Mar 25 2015 5:49 PM
No the essence remote only works for sources connected through Essence box -- it doesn't pair with other products -- to my knowledge.
benoit
France
Posts 646
benoit replied on Wed, Mar 25 2015 5:53 PM
AnalogPlanet
Vienna, Austria
Posts 678
As a matter of fact, previous statements is wrong (working only with Essence box).
It can be used for many other products, Google is your friend:
Hyperlink
TWG
Posts 1,672
TWG replied on Thu, Mar 26 2015 6:08 AM
Yes, I can confirm that the Esssence remote works with other products, too.
I paired it with my Sony Xperia Z2 tablet and it works as Bluetooth volume control or play/pause in the Walkmann application.
Very nice!
benoit
France
Posts 646
benoit replied on Thu, Mar 26 2015 7:24 AM
This could be perfect if I could pair one with my Mac and use it when I stream music!
benoit
France
Posts 646
BillC
Posts 121
BillC replied on Thu, Mar 26 2015 9:42 PM
I use it for my HTPC and playmaker. Works well much prefer using the wheel then buttons Big Smile
ilPadrino
Posts 16
ilPadrino replied on Fri, Mar 27 2015 8:53 AM
When you use it with the Playmaker, do they have to be in line of sight?
or is it enough that they are in the same room? To my understanding they communicate via IR.
TWG
Posts 1,672
TWG replied on Fri, May 8 2020 12:18 PM
Has anybody tested if an Essence remote works with a Beolit 15 or 17 via Bluetooth to control the volume?
leosgonewild
Helsinki, Finland
Posts 2,373
You can’t pair them.
TWG
Posts 1,672
TWG replied on Sat, May 9 2020 7:02 AM
Thanks.
leosgonewild
Helsinki, Finland
Posts 2,373
You could pair it with your android phone and “control” the 15/17 that way.
Or get a 12, that has IR 😀
Page 1 of 1 (13 items) | RSS
