Beolink 1000 remote programing
This post has 4 Replies | 2 Followers
Paco0657
Posts 1
Paco0657 Posted: Sun, Mar 29 2015 3:01 AM
Can anyone help me to program a beolink 1000 remote? I have not used this system for a long time, and I cannot get it to work. Only manually
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Mar 29 2015 4:14 PM
Paco0657:
I'm confused.  The Beolink 1000 is just a button remote with no screen or programming options.  What is it you are trying to do?
Dave.
RussR
Posts 63
RussR replied on Tue, Mar 31 2015 11:02 PM
Which system? Generally you would have the audio system in standby and then nester sound 1store on the remote
We kid because we love.
Ben_S
UK
Posts 631
Ben_S replied on Tue, Mar 31 2015 11:11 PM
Your Beolink 1000 should not need programming as such. It should just work if you direct it at the Beomaster in question.
Anders Jørgensen
Denmark
Posts 350
Maybe it's dead and need batteries or a new printboard. A dealer should be able to help you with a new board.
Otherwise push AV button to see for reaction will work afterwards.
If the thing you want to control is in option 0 then your remote will not work either.
To change option setting:
Push sound, 1, store and the main master should flash for ok. Then it should work.
Page 1 of 1 (5 items) | RSS
