Hi All
I have just purchased a lovely 2300 Beocentre. It worked fine when I bought it but when I got home and set it up it will not read the CDs.
I load them and it spins for approx 2 seconds then stops.
it is not showing the CD info.
Has anybody got an idea what the problem may be please ?
Regards
Mal
Replace the laser, if it has CDM12 or CDPRO (straight line).
Raplace caps on servo board, if it has CDM4 (arc).
//Bo.A long list...
Thank you
How do you know which one is which ? and where do you go to replace the laser.
RegardsMal
