Beovision 32 - Solving HDMI and audio connections
toby64
Posts 2
toby64 Posted: Fri, Apr 3 2015 4:31 PM
I have an Apple TV connected to a Beovision 32 (GB2? - December 2008) using the following connections:
   Video: HDMI > DVI-I
   Audio: RCA > SCART (using AV3)
I also have a BT YouView box connected using SCART > SCART (using AV1)
I would like to use the DVI-I for both sources to get HD from Apple TV and YouView and am thinking about buying a Neet HDMI TRUE MATRIX - 4 Input 2 Output (4x2) Switch / Splitter.
Any advice would be appreciated. I am a bit concerned about:
(1) Whether this will work
(2) How best to set it up
(3) Any potential HDCP compatibility issues.
Many thanks
Toby
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Apr 3 2015 5:39 PM
If it is a Beovision 7-32 it might have component input as well, red, bleu, green rca inputs....
Ralf
toby64
Posts 2
toby64 replied on Fri, Apr 3 2015 6:15 PM
Thanks Ralph. Would that be a better option than SCART? Here's a diagram of my connections.
Toby
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Apr 3 2015 7:28 PM
Much better, it should be HD ready. Using mine at 720p resolution with a PS3.
Page 1 of 1 (4 items) | RSS
