BEOgram 3400 - preamp
cspowers
Posts 2
cspowers Posted: Sun, Jun 3 2012 10:30 PM
I have an older turntable (b&o beogram 3400) and it has a mmc5000 cartridge. i know i need a phono preamp but some preamp sellers say works with moving coil, moving magnet or works with both,,,,, my question is the mmc5000 considered moving coil or moving magnet,thanks
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
cspowers:
It is considered as a moving magnet design although the output is approx 50% of a "normal" moving magnet cartridge.
In my opinion, you are best to cosider a pre amp with an adjustable output to compensate for the somewhat lower output from the cartridge. I use a TC770LC available from www.phonopreamps.com  with excellent results.
Regards Graham
cspowers
Posts 2
cspowers replied on Sun, Jun 3 2012 11:38 PM
Thanks JoeyBoy for the info and the quick response .... like your preamp suggestion as well .... also looking at some with usb output to capture and playback on a Sonos sys
Page 1 of 1 (3 items) | RSS
