Hi, one of my S80.2 recently lost sound out of its mid and low frequency drivers. The issue is with the speaker not the amplifier, and I'm assuming it is with the crossover circuit. However the crossovers were overhauled a few years ago (according to the guy I bought the pair from a year ago). Inspecting the crossover the caps look great and so does the inductor, it all looks brand new. Looking for some help on diagnosing the problem piece, or possible other issues. Thanks
Check the overload protection switch.
--mika
Also check all connections in case one or two have become unsoldered.
Dave.
I´v got a crossover filter if needed:
http://archivedforum2.beoworld.org/forums/t/10080.aspx
http://tinyurl.com/qj9cjsf
tamtapir: I´v got a crossover filter if needed: http://archivedforum2.beoworld.org/forums/t/10080.aspx /***
The Beovox S80.2 filter is different.
I did, and it hasnt tripped
I did notice today that the mid range speaker is actually working it is just the Bass driver that has zero signal. I'll have to open the speaker up again but last time I checked it looked like it was all soldered together very neatly
