How do I delete and intercom (INT) entry? Beoline & Beocom 1
This post has 3 Replies | 2 Followers
Ted
Denver, Colorado
Posts 2
Ted Posted: Thu, Apr 9 2015 2:17 PM
Hello!
I recently acquired a system with a Beoline base & three (3) Beocom 1 phones.  Everything works fine except for an extra Intercom entry when I press the INT button.  Apparently, the "system" is telling me that there is another phone registered to the base, which I don't have.  How do I delete the unwanted intercom (INT) entry???  THANKS!
Ted in Denver, CO
Ola Hansen
Sweden
Posts 10
Reset the base and start over with the phones you have?
Ted
Denver, Colorado
Posts 2
Ted replied on Thu, Apr 9 2015 8:10 PM
Not quite sure how to do that... I find all kinds of information on resetting a PSTN base (restart button) but have not had any luck on ISDN systems.  Closest thing I found is the 9#9#9*HOLD action.  Does this work???
THANKS!
5:8:13
UK
Posts 48
5:8:13 replied on Fri, Apr 10 2015 7:29 AM
Hello
I think you need to access the MENU options on a handset then you can manage the system
I am not sure if this might be helpful.  I have a mixture of Becom 6000 (3) and Beocom 2 (2) all mk 1 working from the old style (squarish) PSTN
Using a BC6000    DOT   followed by  7 gives the menu options
Rotating the dial to MENU 7 (HANDSET/BASE) offers
HANDSET NAME; SELECT BASE; REGISTER BASE; REMOVE BASE; REMOVE HANDSET; COMMON; PERSONAL; AUTO REGISTER; PIN CODE;
from REMOVE HANDSET you have a list of the handsets registered to the system and you can select any and remove or mange the system from any handset
Page 1 of 1 (4 items) | RSS
