Beolab sound bars???
This post has 8 Replies | 2 Followers
Kirky1980
Posts 30
Kirky1980 Posted: Fri, Apr 10 2015 7:04 AM
Hi all I'm going to be moving me TV onto the wall in me bedroom and looking at getting something for the sound, wondering what speakers are good for this as been looking at beolab range 7.1/7.2 or 3500 etc the TV is only 32 inch so don't want anything massive so any help would be great thanks
Weebyx
Denmark
Posts 1,213
Weebyx replied on Fri, Apr 10 2015 7:40 AM
I am using a BL7.2 as soundbar for my Samsung tv, optical out from the tv, into a Beosound 3000 via optilcal->coax converter.
The sound is perfect...
/Weebyx
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Apr 10 2015 7:43 AM
For a 32 Inch TV a 7-1 will look much better (was offered like this with Beovision 7-32).
Ralf
leosgonewild
Helsinki, Finland
Posts 2,373
Go for the 7.1!
Aussie Michael
Melbourne, AU
Posts 3,730
TWG
Posts 1,672
TWG replied on Sun, Apr 12 2015 11:10 AM
Can the Beolab 7 series speakers only be used as center speakers or as full stereo speakers? I've never heard them.
I think the Beolab 3500 will - sound wise - only be usable as a sound bar or center speaker for a small room as it has not the best sound for loud action movies. :)
Aussie Michael
Melbourne, AU
Posts 3,730
TWG:
Can the Beolab 7 series speakers only be used as center speakers or as full stereo speakers? I've never heard them. I think the Beolab 3500 will - sound wise - only be usable as a sound bar or center speaker for a small room as it has not the best sound for loud action movies. :)
but wont the 3500 have the clock visible in the middle? I cant remember
Millemissen
Flensborg, Denmark
Posts 14,680
TWG:
They are full-blown stereo speakers - and can be used as center speakers, if set in the configuration.
Note: the 7-4 is a dedicated center speaker.
The BL3500 could be used, but to set it up as a 'normal' speaker is a bit tricky - and not worth it, imo.
Think of the current prices for the 7 series and go for the 7-1 - you won't regret that.
TWG
Posts 1,672
TWG replied on Mon, Apr 13 2015 12:08 PM
Thank you Millemissen and I hate you for that information: Now I've started to think of buying a Beolab 7-1 or -2. Wink
Page 1 of 1 (9 items) | RSS
