Beolit 12 as multi speaker system
This post has 11 Replies | 2 Followers
steinzeug
Posts 14
steinzeug Posted: Fri, Apr 10 2015 4:02 PM
I have both the Beolit 12 and the 15. I sent the 15 back and got a second beolit 12. The sound on the 15 had lost the all the fantastic warmth of the Beolit 12, so even with the flakey wifi connection and the battery issue, for sound the Beolit 12 is much better IMO.
I sometimes use the two Beolit 12s as multiple speakers around the house, which is a nice extra. However what would make this combo incredible would be able to use them as a stereo system (one speaker play left channel and one speaker play right channel)  that would compete with Sonos, but I suppose it would also compete with B&Os more expensive systems!
I really wish someone had a software solution for that!
Millemissen
Flensborg, Denmark
Posts 14,680
You could feed two BeoLits with a right respctively with a left signal through their line-in connection.
But I am sure this would be a 'bad solution', since the speaker is conceived as a stereosystem, and you would not use 'all of it'.
Another way to do it - perhaps - is to use a cable that splits a mono signal into a RCA (L/R) connection (double mono).
But overall I am sure the result will be disappointing - if you compare it with a 'real/normal' L/R speaker setup..
The BeoLits were created and tuned to work as a standalone speaker system!
steinzeug
Posts 14
steinzeug replied on Fri, Apr 10 2015 4:26 PM
steinzeug
Posts 14
steinzeug
Posts 14
steinzeug replied on Fri, Apr 10 2015 4:32 PM
There must be another way, using software! Smile
elephant
AU
Posts 8,219
elephant replied on Sat, Apr 11 2015 3:10 AM
steinzeug:
I have wanted the same capability but for the A9.
In some ways I think the A9 is a descendant of the Redline series.
I loved the RL60s we had on loan in place of my S55s.
However SWMBO was happy to see them go.
And I am having trouble getting her to let go of the 6000s
BeoNut since '75
steinzeug
Posts 14
steinzeug replied on Sat, Apr 11 2015 8:54 AM
How come Sonos can send left and right channels to tp their stereo speakers and not B&O?
Millemissen
Flensborg, Denmark
Posts 14,680
Of course you can do that.
The big question - however - is, if that is a good idea?
Generally speaking a loudspeaker should be used for, what it is designed and tuned for....
...and the BeoLit's - as well as the A9's - are tuned for being used as a single speaker (with stereo content).
Try it out - if you like it, I can say nothing against it.
steinzeug
Posts 14
steinzeug replied on Sat, Apr 11 2015 9:20 AM
Problem is you can´t do it, not with any third party software I have found or via apples airplay/itunes set up.
Millemissen
Flensborg, Denmark
Posts 14,680
You don't need any software to test that!
Just feed the speakers with a right respectively with a left sgnal to see if you like the sound of that sort of speakers combination.
If it works/if you like it, you can ask your question, whether there may be a software for doing the same.
I guess you are looking for a wireless solution for it?
Btw - which kind of benefit/improvement for the sound do you expect?
steinzeug
Posts 14
steinzeug replied on Sat, Apr 11 2015 9:55 AM
yes, a wireless solution is the whole idea :)
steinzeug
Posts 14
steinzeug replied on Sat, Apr 11 2015 10:24 AM
The Beolit 12 has a really beautiful and full sound, but stereo separation (of obvious reasons) is almost non existent.I have two Beolits set up in my home, they sound great, but stereo separation would make the audio appear more spatial set up asd a multisystem.
As said, Sonos can do it, and it sounds great.
Page 1 of 1 (12 items) | RSS
