My BL3500 suddenly do not react to commands from the remote. Tried with several, so there is no problem with the remote. Tried to power off/on. No joy.
Looked in the Service Manual and is seams easy to replace the board with the IR receiver.
Is it easy?
No soldering?
Is it possible to still order from B&O?
/C
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Common problem with these. I repaired several.
New boards are available, but don't know if the newer versions works with the older 3500's.
Thanks.
Is it just to pop in a new board or are there soldering required?
From what serial number should the new boards work?
No soldering required.
Sorry, I don't know about the serialnumbers between mk1 and mk2.
Beobuddy:No soldering required. Sorry, I don't know about the serialnumbers between mk1 and mk2.
