Friends,
I need to buy DIN-connectors for my BeoVox CX/C-series and I wonder if there is any special connectors that is better for it. The pin outputs on the Beovoxés are sunken into the back and the original cables have a very small connector. I want to use cables I already got without the connectors (don't have the original cables any more). I would prefer to buy on ebay or from a shop in Sweden :-).
Kind regards,Michael
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I have bought at least two kinds of generic female DINs in the past, and they both fit in the recess just fine. I'm sure there are some that don't, though
--mika
I have bought both male and female din plugs from eBay for a couple of sets of CX50's and they fit the small recess just fine
there are snap fit and screw in plugs available and both are just fine, Steve at sounds heavenly has also provided me with some
I´ll buy these http://www.kjell.com/sortiment/ljud-bild/kablar-adaptrar/hogtalare/hogtalarkontakter/kontakt-hogtalare-hona-p39142.A bonus is that I get a lower price if I buy at least four and I need ... four
From the picture, they seem to be exactly the same connectors I have bought earlier somewhere so they should fit.
Perfect!
