sin: Thinking strongly on replacing my BV7 against a V1But no link option, and I want to link my BS9000Would it be possible using Mac Mini, BeoLink Pc Link Player to get control and audio to V1'an
Hi, I am not sure how often Philippe may check the Nordic forums !
Might be better to post into the Mac forum (or send Philippe a PM).
(but instead I placed this copy into the General forum as it is a broader V1 systems integration topic)
You mention the "BeoLink Pc", but did you mean BeoPort ?
I am not sure if Philippe built in support for the BeoLink PC ....
Do you currently have the BS9000 master linked to the BV7?
And to the BeoLink PC/BeoPort ?
You certainly should be able to make this connection:
>BS9K|||| ML|| >BeoPort ---- IR eye|+||+| USB + Audio minijack|+| >MacMini with LinkPlayer|||||| HDMI||| >V1
Adding an Apple TV to the mix or the newly rumoured Mac Mini (see next week's Apple conference) would help make things both richer and more complicated ! (so if you do not already have a Mac Mini, wait at least a week)
The new version of LinkPlayer (currently in beta) has local and distributed (two channels simultaneously) support.
So the new LinkPlayer should be able to send the same audio track to both the BS9K and to the V1 and play in both rooms.
If you have the IR eye installed on the BeoPort it & the LinkPlayer should be able to receive Beo4 commands and operate accordingly.
I believe the LinkPlayer menus would appear on the V1 as well as LinkPlayer video library access.
I believe all the BeoLabs in the V1 room will need to be attached to the V1, not to the BeoPort.
As the V1 has no OUT audio output jacks (other than for PowerLink) the big challenge would be how to get V1 audio into the BS9K room -- I think this will depend upon what devices you want to attached to the V1, such as:
regards Ed
BeoNut since '75
No it's a Beolink PC I have (from first version of Beomedia)
My plan is to have BS9K and V1 in the same room and move my BL speaker to V1 from my BV7 and yes add Blueray etc to the V1.
I would upgrade my Beolink PC to Beoport if needed.
And I will retire my BV7 to my bedroom :-) replacing my old MX3500
I have an MacMini that I will use for this.
>BV7 Bedroom
|| ML
>BS9K Living room|||| ML|| >BeoPort ---- IR eye|+||+| USB + Audio minijack|+| >MacMini with LinkPlayer|||||| HDMI||| >V1 Living room
(I am not sure where my answer to this has gone... the forum seems to have issues today).
Beolink PC is the RS232 version of the Beoink PC2. The Beolink PC 2 has USB, and was later renamed Beoport.
I do not think LinkPlayer will offer a reliable solution for this issue.
The fantastic Video engine of the V1 will be ported to other "proper" beovisions... so personally I'll be waiting.
Beoworld app with direct photo upload and emoticons.
Hi sin
I had the exact same issue, I ended up retiring both the BV7 and the BS9000. My setup is now only the V1 and a NAS server for media.
regards
Jesper
