Hello all
i am considering a beosound moment but I have loads of thoughts that I wonder if anyone could fill in.
i have a ML setup and no Netlink products, currently I play music from spotify to an airport express connected to A.Auv on a beosound 4. That is all the BS4 seems to get used for as I don't listen to analogue radio or CD.
The beosound 4 is very under utilised, I have a pair of Penta connected and play music over ML through the entire house.
any thoughts on the below questions / statements:
has as anyone connected the moment to the beolink gateway?
Can the moment send music over ML?
can the moment be actives from ML rooms against Radio and AAux button pressed.
would I need a beolink converter and delay box.
the beosound 4 sends the source name to the display in the penta can the moment do this?
if I replaced the BS4 with a beolink active can it tell the speakers what source is playing?
does the moment get assigned an option?
Today the BS7 is only allowed in one option or the gateway cannot control it.
any thoughts all
Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230: Hello all i am considering a beosound moment but I have loads of thoughts that I wonder if anyone could fill in. i have a ML setup and no Netlink products, currently I play music from spotify to an airport express connected to A.Auv on a beosound 4. That is all the BS4 seems to get used for as I don't listen to analogue radio or CD. The beosound 4 is very under utilised, I have a pair of Penta connected and play music over ML through the entire house. any thoughts on the below questions / statements: has as anyone connected the moment to the beolink gateway? YES Can the moment send music over ML? actually in your setup I heard it will work can the moment be actives from ML rooms against Radio and AAux button pressed. actually in your setup I heard it will work would I need a beolink converter and delay box. BLC YES; delay box no; all music is in the ML domain; the beosound 4 sends the source name to the display in the penta can the moment do this? I would say now; I wouldn't expect so in the future if I replaced the BS4 with a beolink active can it tell the speakers what source is playing? The BLC doesn't supports different sources to be displayed does the moment get assigned an option? Don't think so; the BLC does get assigned an option Today the BS7 is only allowed in one option or the gateway cannot control it. any thoughts all
See above;
@Seanie
Best wait untill mid-may (week 20) for correct answers to your questions.
Much about the Moment will be different after the SW updates then.
That is - if anyone else already know details - and is willing to share them here.
Millemissen: @Seanie Best wait untill mid-may (week 20) for correct answers to your questions. Much about the Moment will be different after the SW updates then. That is - if anyone else already know details - and is willing to share them here. MM
In contrary with a ML system add a BLC and a Moment you will not have to wait until the update! If you had a NL BV I would agree with MM, but not with your setup.
Yes - you are right!
I overlooked, that there is no NL product (yet) in the setup
Chris Townsend:Do they still have that friendly spaniel? Beovision 7-55 Mk2, Beovision 8-32, Avant RF 28, Beolab 8000, Beolit 12, Beoplay A2, Beocom 2, Beotime, H6, Form 2.
