Just moved the Beovision 8-40 from the bedroom to the living room and as I wanted to connect it to my music system, I discovered that the masterliness plug was not included when I bought it.
Any chance one of you has a spare one? Or knows where I could find one? Apparently my dealer is not very confident this can still be found.
Let me know if you have a solution for me.
Thanks in advance,
Alex
BeoNut since '75
Good morning,
It is actually a Beovision 8-40.
Thanks,
I have one of those, new and boxed. Very simple to fit too!
PM me with the type and serial number of your TV.
Lee
Done,
I've sent you a message with the details.
Let me know if this is what you needed.
