RL 140 Questions
This post has 11 Replies | 0 Followers
Georgie
Posts 8
Georgie Posted: Mon, Apr 27 2015 2:50 PM
Hi everyone, I have 4 RL 140s in my garage.
I have two plugged in to an old pioneer amp, and they sound good but when i raise the volume from my computer they distort and sound bad.
Im in the market to get an amp powerfull enough to power all 4. Would a car amp work?
What would you all suggest?
The way i run my music is from winamp on my cpu then run a aux 3.5mm wire to the amp...
As you notice im not a audio savy person, I just want to play them as LOUD as possible while I'm welding and working on my stuff...
Thanks everyone!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Apr 27 2015 3:17 PM
Welcome to Beoworld !
The Beovox RL140 are very good speakers and quite powerful for their size but they suffer from foam rot.
Check the woofers!
Georgie
Posts 8
Georgie replied on Mon, Apr 27 2015 8:20 PM
thanks dillen! how do i check to see if they are rotted? do i need to take off the cloth and straps?
If they are in okay condition, what shold i do next? look for a more powerful amp?
Thanks again!
Georgie
Posts 8
Thanks again!
AnalogPlanet
Vienna, Austria
Posts 678
Just google "RL 140 rot" and check images.
Georgie
Posts 8
Georgie replied on Tue, Apr 28 2015 6:12 PM
ok no foam rot here...they look pretty un used.... maybe my amp is just too weak??
I have a pretty good quality car amp, its for speakers. 4 channels  at 100 watts rms each...would i be able to use it? would the sound quality be good?
Georgie
Posts 8
Georgie replied on Tue, Apr 28 2015 6:16 PM
i also ordered this cable...i thought maybe my 2$ cable could also be a problem
https://www.ramelectronics.net/iPro2-M2RCA.aspx
Georgie
Posts 8
Georgie replied on Tue, Apr 28 2015 6:21 PM
here you can see where im using them.... you can see one is way up in the corner...so its a deep and high garage...i want to be able to BLAST them....
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Apr 28 2015 6:27 PM
I think this is the most hardcore B&O installation I've ever seen. Respect Yes - thumbs up
These speakers will need (and can handle) a hefty amp to play loud. The advertised car amp "watts" are typically very weak in practice.
--mika
Georgie
Posts 8
Georgie replied on Wed, Apr 29 2015 6:27 PM
shoul i get a preamp or a power amp? I guess i should be looking for something that has 4 channels @ 200 wts rms??  Would i be able to use a 5 channel power amp and add my 10" car subwoofer??
Georgie
Posts 8
should i get a preamp or a power amp? I guess i should be looking for something that has 4 channels @ 200 wts rms??  Would i be able to use a 5 channel power amp and add my 10" car subwoofer??
the_o_master
Posts 856
You could try to find good working Beomaster 8000. It would drive your RL-140 nice but those beasts (BM8000) are not easy to find (at least in good working order)...
Vintage Bang & Olufsen
Page 1 of 1 (12 items) | RSS
