Beocenter 7002 VU indicator fault
This post has 5 Replies | 0 Followers
John
Yorkshire England
Posts 104
John Posted: Sat, May 2 2015 10:43 AM
This BC7002 has been working without fault for 6 weeks.  Today I noticed the vu leds were on when playing a record or when using radio, this was intermittent and did not bother me.
Then when playing tape fault happened all LEDs lit and a loud Machine Gun effect on the audio.
I have disconnected set from mains supply for 5 minutes, but same intermittent results when plugged in again.
I see C9 C10 C11 could cause the fault and I intend replacing them first.  The display is not always "full on" with red LEDs flashing, sometimes 1 green LED is on, sometimes more are on.
I have had a lot of time looking at the circuit and can not find where the wires from Plug 29 go. Had a good look on Diagrams 2 and 5. help please.
I do not want to do a blanket change of caps, Could  dirty contacts on a relay cause this fault?
I have never tried to set the timer for the tape.
Any Ideas of fault before I open set up.
   TFL, John.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, May 2 2015 6:33 PM
Replace the two relays on the tape controller board as the first thing.
They are known troublemakers.
John
Yorkshire England
Posts 104
John replied on Sat, May 2 2015 7:31 PM
Thank you Martin, Don't these relays respond to cleaning contacts?
   John.
John
Yorkshire England
Posts 104
John replied on Sun, May 3 2015 11:13 AM
Hi Martin, Before I open set, can you supply me with two relays?
   John.
Dillen
Posts 13,191
Dillen replied on Sun, May 3 2015 7:39 PM
That depends on the exact type used.
Start with a blast of contact spray. It will not be a lasting solution but it will tell you if you're on the right track.
John
Yorkshire England
Posts 104
John replied on Mon, May 4 2015 5:56 PM
I think I have cured problem with switch cleaner, just hope I have not spoken to soon. Both relays have part no 7600045 relay 6v. Two different relays were fitted,  one had markings "Type C2V-2  6volts   the other looked vey similar but height measurement was different, and no markings.  Any one know coil resistance ?   I know I should have measured when I was there.
   John.
Page 1 of 1 (6 items) | RSS
