Beosystem 3 faulty?
This post has 4 Replies | 0 Followers
OldJack
Split
Posts 371
OldJack Posted: Mon, May 4 2015 4:33 PM
Hi!
Recently I purchased Beosystem 3 from ebay,in order to integrate with the rest of the system in signature and new Samsung  UE55HU7500 led tv.Seller declared BS3 latest version,fully working.
Now when I plug in power cable to BS3, there is green led light on it,just for 3-4 seconds,and light goes off.
Q: Is it normal,or I have faulty BS3 .
(pls note,I have not made any initial setup on BS3 yet)
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, May 4 2015 11:11 PM
From memory, the green light comes on - then goes off.  If it goes amber, you have a problem. Green, then off, is fine.
I hope you were given the PIN code for the unit?  If not, you'll need it!
Lee
OldJack
Split
Posts 371
OldJack replied on Tue, May 5 2015 12:02 AM
Hi 9 LEE,
Thanks yours response.Yes,green led ,then off...hopefully BS3 unit is ok.And i was not given Pin code.
It was purchased from UK ,TMC4500 (The Legobay) , so next morning will ask them for PIN code.
Furthermore,how can I access setup menu/make BS3 innitial setup?
As I read from the forums,I need an IR receiver connected to BS3.
Q1) Will STB PUC ir blaster/transmitter for B&O TVs do the job?
Q2) Can I make innitial setup on BS3  using my (still good working) Beovision 3/32 with BEO4 remote? And how?
Kind regards,Frane
Dave Farr
France
Posts 2,283
OldJack
Split
Posts 371
OldJack replied on Tue, May 12 2015 1:22 PM
Thanks Dave
Page 1 of 1 (5 items) | RSS
