Difference between Beolab 3 MK I and MK II
This post has 13 Replies | 2 Followers
Manbearpig
Posts 908
Manbearpig Posted: Tue, May 5 2015 7:30 AM
Dear members,
I know, there has already been a thread about the Beolab 3 MK II, which, however, left me somewhat in doubt. So what are the differences between the Beolab 3 MK I and MK II? It was suspected that the MK II version has been "upgraded" because of cost cutting. Sound quality is supposed to be the same nevertheless. Is this the case? If so, are there any other differences in terms of quality or durability? Is MK I or MK II more desirable from your point of view? Any opinions much appreciated. Thanks!
Greetings,
Kai
PathElectronics
Posts 8
My understanding is that the bass driver and passive radiators are different. I believe the EQ in the amp module was changed slightly to make them sound the same. It's a very slight difference indeed.
MKI replacement amp module (at least the US version) has been discontinued, so I think if buying used, the MKII would be the way to go.
Nathan
PathElectronics
Posts 8
Nathan
beojeff
USA
Posts 2,012
beojeff replied on Tue, May 5 2015 11:02 PM
PathElectronics:
Nathan
Is this the Path Electronics B&O authorized service technician in Arlington Heights? If so, I highly praise your work and recommend your services to other BeoWorlders! Welcome to BeoWorld!
Aussie Michael
Melbourne, AU
Posts 3,730
How would you even know if you had a Mk1 or Mk2
vlohjr1
Posts 553
vlohjr1 replied on Wed, May 6 2015 9:38 AM
Aussie Michael:
I think post 2008 is mkii
Manbearpig
Posts 908
Type numbers inside the accoustic lens when removing the top or next to the sockets will let you know. I don't know from memory which type number represents which MK version. Thanks for the answers.
Greetings
Roger
Norway
Posts 417
Roger replied on Thu, May 7 2015 9:37 AM
Nathan is spot on regarding the tech changes, and I think the bottom line is that mkI and II are the same when it comes to sound reproduction given that they have covered the same number of miles.
The bass and slave units were replaced as they went for different/new materials and improved the production. As stated above, some parts had to be replaced to maintain the sound quality and freq range. The units with these changes came with type no 6871-6877 and where introduced in September 2007.
Roger
Aussie Michael
Melbourne, AU
Posts 3,730
I took the top off mine and the type is 6875 and no mention of the MK
Just says type, item, serial no and country of origin
Manbearpig
Posts 908
Manbearpig replied on Mon, May 11 2015 11:00 AM
Looks like MK 2 then!
Chris Harrison
Peak District
Posts 381
My speakers are 6892. - I'm guessing Mark 2?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
pauljrog
Posts 92
pauljrog replied on Thu, Sep 30 2021 8:16 AM
Hi guys can anyone confirm if type 6892 is mk1 or 2. Thanks
Also is mk1 anymore unreliable?
marexy
Posts 710
marexy replied on Thu, Sep 30 2021 8:22 AM
I had MK1 and 2.
Sound is the same. Drivers are the same.
MK1 have some issues with power supply and amplifoer pcb that fails more often.
On the outside is totaly the same...you can check difference by type No.
marexy
Posts 710
marexy replied on Thu, Sep 30 2021 8:24 AM
6892...MK1
Page 1 of 1 (14 items) | RSS
