Need an ir module for beocenter 9300
dueno
Posts 101
dueno Posted: Thu, May 7 2015 4:16 PM
Hi
My beocenter works fine but the ir module is over and there is no more parts in B&o
Has someone an ir module that works?
Dave Farr
France
Posts 2,283
Check eBay.de. Someone had one on there last week complete with the board, battery etc. Dave.
Jason
Redditch Worcestershire
Posts 177
Jason replied on Thu, May 7 2015 9:14 PM
I take it you have checked it's not set to option 0?
Jason
Posts 177
Jason replied on Thu, May 7 2015 9:15 PM
And that it's not come loose from the socket inside?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, May 7 2015 10:06 PM
You can send it over for repair ;-)
I fixed one a few weeks ago.
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, May 8 2015 11:46 AM
How transferable are they between the BC8500, 9000, 9300 and 9500?
Dave
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, May 17 2015 12:10 PM
Any progress on this?  The reason I asked about transferrability is that there are 2 units on eBay at the moment:
http://www.ebay.co.uk/itm/221759851140?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/190924552418?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
You'd obviously need to check part numbers etc and I'm not sure which bits you actually need.
Dave.
Beobuddy
Posts 3,972
Beobuddy replied on Sun, May 17 2015 12:58 PM
I can't remember exactly. And that is rather odd, as I regularly have these units.
The difference between the 9500 and 9300 starts with the difference in 2 way infrared. The 9500 has 2 way. The 9300 is based on the ouverture and has only 1 way. The last time I repaired the ir-module for the 9300, it had SMD capacitors mounted on the board. besides the differences between the board I don't remember exactly if you can easily swap the boards. That's beside the fact that 2 way communication will not work obviously.
Page 1 of 1 (8 items) | RSS
