Bang Olufsen Keyring A8. I want to start DTV not TV
Imperator1000
Posts 19
Imperator1000 Posted: Sat, May 9 2015 3:06 PM
Hello,
I have a Beovision 7 - 32 and the Keyring but by pressing "Video" the TV starts. I want it to start the Beovision with DTV because I have a Sat-Receiver. Anything possible over the service menu??
Thanks.
elephant
AU
Posts 8,219
elephant replied on Sun, May 10 2015 1:25 AM
There was a trick I found in the forum ( but which I have forgotten ) which enabled me on my BV8 to disable the now useless analogue TV association with the [TV] button and replace it with the dud it's TV association and let me move my FOX association to DTV rather than V-AUX.
Does that give you something like what you are wanting ?
BeoNut since '75
Barry Santini
New York
Posts 543
If u have a ota tuner, disable it in the menu. Then dtv can be assigned to your set top box
Millemissen
Flensborg, Denmark
Posts 14,680
That goes only for the BV//10 and BV7 with newer SW versions installed.
elephant
AU
Posts 8,219
elephant replied on Sun, May 10 2015 11:30 PM
Millemissen:
Sorry MM, but also my BV8-40 as I stated earlier.
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
I - as a proud BV8-40 owner - do know that!
It was a typo, as I now see.
Should have been 'the BV8/10 and BV7 with newer SW' in my post above.
Page 1 of 1 (6 items) | RSS
