The Beomaster 4400 has an over-load circuit and I am wondering does it protect against a speaker hard-short?
I have had an “issue” with my second pair of speakers in that they are wired at the connection. Needless to say I am VERY careful about connecting these wires, but over time, say 6 months it seems a single strand of copper wire manages to touch the other terminal.
This “situation” was corrected permanently today by soldering the wires at the connection.
However, I am wondering if the horrendous sounds and resulting sparks arching between the posts might have damaged the Beomaster 4400.
All appears normal as both speakers and amplifier “appear” unaffected.
So simple question, does the over-load circuit protect the 4400 against this sort of problem?
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century, S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase, B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
The simple answer is no.Basically, the protection circuit protects your speakers if a failure occurs in the Beomaster - not the other way around.
I see. Then I must be grateful that it appears that no real damage was done to either amplifier or speaker.
This explains why the over-load lamp didn't even flicker.
Going forward, this "problem" can not repeat.
Thank you Martin for your much appreciated expertize.
