BeoMaster1000 with BeoVox2500 Cubes
This post has 21 Replies | 1 Follower
Laurent1602
Belgium
Posts 39
Laurent1602 Posted: Thu, May 14 2015 4:17 PM
Hi everyone,
I'm new in the B&O world and I've already got a question!
My grandmother gave me her old B&O installation because they have replaced it with something more modern and it was just sitting on the shelve there. It's a BeoMaster1000 (with black keys), 2 BeoVox2600 and 2 BeoVox2500 Cubes.
Afaik the speakers have always been connected to speaker output 1, and the tweeters to output 2. But after reading a bit on the net it seems that the Cubes were never meant to be connected to the output directly. Should I place something in between or should I just disconnect them on higher volumes? I found a thread where this was discussed but is was for another amplifier and I'm not sure if it's the same.
I'm very excited about my new setup, and can't wait to start using it once I know I'm not ruining it! All speakers are working great except one BV2600 so I will be replacing capacitors in these, hopefully this solves that issue as well!
Thanks for your time and answers!
Laurent
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 14 2015 4:41 PM
Hi Laurent, and bienvenue !
Please NEVER connect the cubes to the amp, even for testing purposes!
They MUST be plugged at the back of the Beovox 2600 speakers, no matter what.
There is a fair chance of destroying them if you even try to plug them to the amp, and push up the volume!
After all these years you will need to replace the capacitors inside the Cubes and '2600. We can guide you if you need to be advised.
Jacques
Laurent1602
Belgium
Posts 39
Thanks for the fast reply! The capacitors for the 2600 are already ordered and I've found out how to open the speaker so that's fine. I could use some help for the 2500 though. How can I open these? And how should I connect them to the amp since the 2600 has no connector for the 2500.
For now I only connected the cubes to the amp to test them on a very low volume so they should be fine. I even believe my grandmother always used them like that but it's hard to believe a B&O dealer sold it like that back then.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 14 2015 5:14 PM
Oh yes, 2600, not 2400 !
You will have to make an adaptor, a special "box".
Look here for the capacitor, and there for the adaptor by Frede.
Jacques
Laurent1602
Belgium
Posts 39
I only need to make the part of the drawing circled with 'connector box' I assume? Should be easy to do!
Thanks for your advice! Nice pair of BV5000's you've got there by the way, gorgeous!
If I have anymore questions in the process I'll post them here, and if it's all fine as well of course!
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 14 2015 5:50 PM
Laurent1602:
Yes. Do publish some pictures once you're done - or even right now, so that we can behold your setup!
But how did your grandparents connect the Cubes to their system then?
Jacques
Laurent1602
Belgium
Posts 39
I believe they always connected the Cubes to the 2nd speaker output, which would be strange but they survived somehow.
Of course I want to post some pictures of my setup!
Here is my BeoMaster1000 (together with his modern Danish friend from Libratone and Dual 1219)
Here is one of the BV2600
And the Cubes
And the other BV2600 is already opened up because I needed to know which capacitors to order of course
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 14 2015 6:28 PM
Thanks for the pictures ; now you are a fully accepted member Big Smile
Nice, well cared for elements  Laurent!
Jacques
Laurent1602
Belgium
Posts 39
Thanks :D
It deserves some more place on my desk but for now there's none. That's coming though!
The biggest concern (in terms of looks) is the dust cover on the Dual that's broken and missing some pieces but I'm planning on making one myself with some plexiglass.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 14 2015 6:48 PM
Mmm... Get a nice Beogram 1000 instead of the Dual (a fine turntable in its own right). Just kidding. I think... Stick out tongue
Jacques
Laurent1602
Belgium
Posts 39
I'd love to get a BeoGram to complete the setup... Someday!
Laurent1602
Belgium
Posts 39
Just one quick extra question, what's the meaning of the symbol circled in red?
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 14 2015 9:41 PM
Don't bother, it's nothing.
Jacques
tournedos
Finland
Posts 7,357
tournedos replied on Thu, May 14 2015 9:46 PM
It is something - it's a virtual test point for the simulation software and you can safely just ignore it Big Smile
--mika
Laurent1602
Belgium
Posts 39
Haha, ok, thanks again! Big Smile
Laurent1602
Belgium
Posts 39
Allright, I have ordered all components including those for the adapter box, the capacitors should be here soon, the rest could take some more time but until then I should be able to enjoy the BV2600's alone.
The only problem left was which power rating should the resistor for the adapter box be? So I did an online simulation and it said 10W would still burn...
Just to explain my thoughts, maybe the error is in there. The speakers are rated at a power (P) of 30W and have an impedance (R) of 4 Ohm, so the maximum voltage (V) should be, according to P = (V^2)/R, 11V (which seems a lot to me).
With this information I made an online simulation which showed the circuit would burn. According to the simulator I would need a resistor able to handle more than 35W??
And as a reference, I made the original circuit of the BV2600 as well, with all original components, and it would also burn, so I believe I made a mistake in my reasoning somewhere Big Smile
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, May 20 2015 6:18 AM
Do not worry, it won't burn or even get anywhere near hot!
To put it simply, the series low value capacitor will greatly reduce the electric energy that will be applied to the HF units. No worries here!
Jacques
Laurent1602
Belgium
Posts 39
OK, so a 10W resistor should be enough? Or even 5W?
kallasr
Germany
Posts 2,562
kallasr replied on Wed, May 20 2015 10:10 AM
I used to have this Setup:
https://www.youtube.com/watch?v=Bgh0wl2Fpuo
The cubes connect at the back of the Bevox 2600.
Sold to make space for Beolab 5000/Beomaster 5000.
Should have kept the Beovox cubes....but this was just at the early stage of the beovirus ;-)
Ralf
Laurent1602
Belgium
Posts 39
Very nice setup! I'm not planning on going bigger/better but I'm afraid it's a virus indeed. Just like old cars, I'm infected with that one as well Big Smile
Are you sure your Cubes were attached to the BV2600's? Because mine have no connectors on the back. Or were they attached to the BeoMaster?
Or maybe there were 2 different BV2600 models, but I can't find anything about that.
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, May 20 2015 1:28 PM
Laurent1602:
I use 7W ones.
Jacques
Laurent1602
Belgium
Posts 39
chartz:
I use 7W ones.
Allright, thanks!
Page 1 of 1 (22 items) | RSS
