Beocord 6000 vs 9000 PPM LED Packs
This post has 5 Replies | 0 Followers
Bristol603
Posts 50
Bristol603 Posted: Thu, May 14 2015 6:57 PM
I have a BC9000 with two failed LEDs and a BC6000 with all working LEDs. Are these LED packs interchangeable?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, May 14 2015 7:15 PM
If by LED packs you mean the displays, then yes to the large red 4-digit display.
But do be careful when working/handling, it's vibrations that kill them.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Thu, May 14 2015 7:37 PM
Don't discard the display module(s) with the failed LEDs. They can be made to work again with SMD LED replacements...but the original display module is needed.
Bristol603
Posts 50
Sorry, I wasn't clear. I meant the PPM bar displays rather than the 7-segment digit displays. Are the bar displays interchangeable?
Dillen
Posts 13,191
Dillen replied on Thu, May 14 2015 11:06 PM
I prefer to repair rather than replace, but I seem to remember them being identical.
Check the number (83...) stamped at the backside.
Bristol603
Posts 50
Yes the PPM bar graph displays are interchangeable. The part number of both is 8330014. I have now noticed that the 6V 1W bulb has blown (also in my parts BC6000).
Page 1 of 1 (6 items) | RSS
