This issue in fact bothered me for a while. Once I ripped a single CD into FLAC or AIFF, it is pretty okay as long as the folder only contain one CD tracks. eg, if you have a CD consist of 10 tracks, you ripped it and put under the album folder , BS5E play it from #1 to #10 in sequence.
But once you have CD box, let's say 2 CDs under one album folder, then you have a problem. the BS5E will play the #1 of Disc 1 and then play the #1 of Disc2, followed by #2 of disc1 and then #2 of disc 2.
I use itunes to manage my CDs. In itunes, 2 CDs with the same album name showed under one folder and played in sequence. but it doesn't on BS5E. I tried different means , eg when naming the tracks, I use the format disc no. track no. title, so the track file name start with the disc no. but all failed when BS5E played them.
The only way worked is to have a different folder for different disc, i.e. treat every disc as a different CD. But then you have a 10CDs set ( eg. Beethoven complete piano sonata set), then you end up with 10 CD covers with the same picture in BS5E.
Anyone who has the experience how to solve it ?
