having dreamed of owning a pair of beolab 8000's for a very very long time i managed to persuade the wife to treat me at my expense lol
unfortunately in the quest to buy I came across a pair of Beolab 1s which changed my outlook and they are now taking up prime position in the room.
sadly these are curently my only b&o product and they are connected to a panasonic surround sound system using a convertor from SoundsHeavenly which does the job of dropping the amplified signal down to line level.
the sound from the 1s is amazing, but this has now prompted me to start looking for somethng from B&O to use as the rear surround speakers.
Based on looks id like Beovox 3000s and these could be run from the existing panasonic without having to worry about mains power, alternatively I could potentially fit either 4s, 6000s or 8000s with a bit of messing around.
The room isnt very big and I think 6000s or 8000s would be overkill, and ultimately what ever speaker is chosen will only be providing rear fill and there is currently no plans to change the panosonic unit until it fails.
what would others recommend and why?
I have a 7.2 setup with BeoLab 1 speakers providing the front left and right channels and two pairs of Beolab 8000 speakers providing the rear and surround channels. I find the BeoLab 4000 speakers to sound better than the BeoLab 6000 speakers. However, I think it really depends on what is practical for your room. The BeoLab 4000 speakers have the benefit of being wall-mounted and can be directed toward the listening position. The BeoLab 6000 speakers are great floor-standing speakers and almost disappear with any decor.
I have the Beovox 3000 as well and find that the sound is not up to par with the 4000s. A disadvantage of the 3000 speakers is that you are limited with your ability to direct the sound toward the listening position.
I agree with beojeff and would go with either 4000s or 6000s.
The 6000s would mirror nicely the shape and aesthetics of your BL1s whilst being much smaller and easier to accommodate, but it really does depend on what space you have available.
My cinema room is small - less than 4m x 4m and I have two doors in one of the rear corners so floor standing surround speakers are not an option for me. I mounted a pair of 4000s horizontally, on the side walls near the rear of the room (above door height) and aimed them slightly downwards towards the listening position. They have performed admirably as surround speakers, both previously in conjunction with a pair of BL8000s at the front, and more recently with a pair of BL9s at the front.
Martin.
With BL1's front I have already had several rear configurations.
-BL 1's. A bit of overkill but nice with movies.
-BL 3's. Precise. Recommendable.
-BL 6000. Warm sound, recommendable.
You can also tweak listening distances in the setup to achieve a front or rear bias.
BL 6000s are designwise matching to your BL1. However, I still would go for BL4000s because I've never found 6000s soundwise satisfiying. (personal oppinion)
Beovision Avant 55 / BV 11-40 / BV7-40 / Beovision Avant / Beosound 9000 / Beosound 5 Encore / Beosystem 4500 / Beosystem 6500 / Beocenter 9000 / Beolab 5000 / Beolab 18 / Beolab 19 / Beolab 11 / Beolab 17 / 3 sets of Beolab 4000 / Beovox Red Line 60.2
BeoLab 6000.
Match the BeoLab 1 aesthetically and are fine as surrounds.
Lee
9 LEE: BeoLab 6000. Match the BeoLab 1 aesthetically and are fine as surrounds. Lee
And if you prefer, can be wall mounted as well as floor stood. This could raise them a bit further to enhance the sound if like us you have a high backed sofa which cab otherwise block a lot of the sound.
Dave.
Thanks guys.
Based on info provided Ive now disregarded the beovox.
im not keen on the look of the 4000 so That leaves me looking at 6000s & 8000s
8000s were what I wanted orginally (because of the pointy bottom) but 6000s do match the 1s much better.
both seem to be dropping in price on a well known auction site so it going to be down to what comes up within budget.
looking at 6000s there appears to be a vertical port on the front near the top.
some of those being advertised have what looks like neatly applied black mastic holding this on whilst others have a yellowish mess. Is this normal or is this a poor repair/service?
apart from speaker foam deterioration is there anything else to watch out for?
which ever option is chosen i will be looking to wall mount so thats something else to look at soon.
