hi
In order to gain some space, I need to dismantle my bv 7 40 motorised florr stand. Where can I find a manual ?
I don't know how to remove the base ?
thanks for your advices
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
There are 4 Alan key bolts underneath , sometimes the holes are covered by black tape.
you may have to turn the base to line up the holes with the bolts.
careful not to scratch the base plate when the legs come off
jason
Thanks you so much Jason.
you are right there are black tape on it.
