VNC or remote desktop to BM5?
This post has 10 Replies | 2 Followers
Stan
Chicago-area USA
Posts 869
Stan Posted: Mon, May 18 2015 3:11 PM
Has anybody tried using VNC or remote desktop to control your BM5 while in service mode?
I'm thinking about doing some software tinkering, and it would be a lot more convenient to access from my office desktop rather than from a physical keyboard connected to my BM5/BS5.  Does the embedded XP even support remote desktop?
Thanks in advance,
Stan
BeoMotion
Posts 384
BeoMotion replied on Mon, May 18 2015 6:42 PM
I suggest using TeamViewer. Works flawlessly. There will show up one or two error messages during installation but you can ignore them.
Windows RDP is not enabled and can not be accessed.
What do you want to "tinker"? Maybe we can help...
BR,
BeoMotion.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Mon, May 18 2015 10:45 PM
I can confirm VNC works too.
As a hint - when navigating the BM5 menu remotely (or indeed via a keyboard attached to the BM5), the 'R' key is equivalent to pressing the MENU button on a beo4, so to enter service menu from your remote connection you would press 'R' '9' '0' '0' 'Enter'.
Martin.
StUrrock
Posts 995
StUrrock replied on Tue, May 19 2015 1:25 PM
riverstyx:
Martin.
thanks Martin for that works brilliantly!
only one problem if via the PC I enter NMUSIC I cannot return to the main menu using the PC keyboard
Griebel
Posts 416
Griebel replied on Fri, May 22 2015 3:22 PM
Tried VNC twice on BM5. Worked for a while, but for some reason it suddenly stopped working (I mean the BM5).
Had to perform a restoration each time. I'm not trying it again.
Have no clue why it doesn't work on BM5. Perhaps because it is attached to a BS5?
I'm also using a BM1. Here VNC works perfectly.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Fri, May 22 2015 9:23 PM
Griebel:
Hi Griebel,
Out of curiosity, which vnc software were you using? I've had TightVNC installed on my BM5 for around a year without any issues. I have a BS5 attached too so this hasn't caused any issue for me. I do see the BS5 display side by side with the BM5 display when I connect (if the BM5 is not in desktop service mode), and whilst I can't interact with the BS5 display remotely, I have found this useful at times to see what is playing when I can't be bothered to go to the room where the BS5 is located.
Martin.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Fri, May 22 2015 9:27 PM
StUrrock:
My BM5/BS5 isn't set up at the moment (packed away whilst building works are going on) but I'll see if I can work out a way around that once it's back in place.
Martin.
Stan
Chicago-area USA
Posts 869
Stan replied on Sat, May 23 2015 1:57 PM
Thank you everyone for the information.   I plan to install Spotify connect (following the instructions in the other thread).  One of my reasons for wanting remote access (aside from the obvious convenience) is I only have an apple keyboard to connect to it.  This can be a little bothersome.  All my windows machines are laptops.
Stan
StUrrock
Posts 995
StUrrock replied on Tue, May 26 2015 7:36 AM
riverstyx:
Martin.
Griebel
Posts 416
Griebel replied on Sat, May 30 2015 4:55 PM
riverstyx:
Version 4.3.2 of Real VNC Enterprise.
beolion
Posts 485
beolion replied on Sat, Sep 19 2015 9:11 AM
riverstyx:
Hi Griebel,
Martin.
Hi Martin, thanks for the tip with TightVNC, works like a charm Yes - thumbs up
Page 1 of 1 (11 items) | RSS
