Does this work?
I saw there are RCA outputs on the original apple TV box, obviously you can get a Scart converter to run RCA's etc in.
Any advice?
Ps.... Is Lesley still on here?
Dank.
That shouldn't be a problem Chaka BUT DON'T FORGET, ATV1 DOES NOT support YouTube or AIRPLAY!!! I guess the plus point with ATV1 is its Harddrive built in :)
YouTube is only on ATV3 now and Airplay from ATV2.
Yes i have used a scart converter to component before and its good
I have the ATV1 - still kicking on :-)
