Beovision 5 not starting
chti59
France
Posts 149
chti59 Posted: Sat, May 23 2015 11:22 AM
Hi
I just reassembled a Beovision 5 that was not working at all
So when plugged in you hear the unit clicking on then after a few seconds you hear a clicking sound again.
No response to the beo 4 and the red led light is on and of course stays on....
Any help of where to start will be appreciated.
HardCopy
California, USA
Posts 47
HardCopy replied on Sat, May 23 2015 5:18 PM
Short-circuit the relay (60RL1) on PCB 60.
Link to service manual:
https://www.dropbox.com/s/2gt7088703p2e7s/BV5-service%20manual.pdf
BeoVision 11-55, BeoCenter 2, BeoLab 9s, BeoLab 3s, Beo4/5/6, BeoRemote One, BLGW, Transmitter 1, BeoLit 12, A8, H6, H8
chti59
France
Posts 149
chti59 replied on Wed, May 27 2015 6:49 AM
Thank you HardCopy for your help
PCB 60 exchanged from a working unit, same problem
Red led on but no power to the plasma monitor. I even haven seen while the set is left pluged in the outlet, the fans start turning and going off right away with the relays clicking.
chti59
France
Posts 149
chti59 replied on Sat, May 30 2015 12:12 PM
PCB 60 mains distribution
PCB 4 Main power supply
Moved to a working unit and they are both fine.
Problem must be somewhere else but not in the power supply that is for shure.
As this is a lot of work to change cards from one to another any help will be appreciated.
chti59
France
Posts 149
chti59 replied on Tue, Jun 16 2015 2:33 PM
anyone ???
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Jun 18 2015 8:32 AM
By accident the mains switch on the front of the panel switched off? During startup the chassis communicates with the panel. Without that communication, the chassis will not start (as far as I can remember)
chti59
France
Posts 149
chti59 replied on Thu, Jun 18 2015 4:52 PM
Thank you beobuddy I'll check that and let you know.
Page 1 of 1 (7 items) | RSS
