Beocenter 5000 turntable belt
Thom Chesshyre
United Kingdom
Posts 13
Thom Chesshyre Posted: Mon, Jun 1 2015 10:41 PM
This seems like such an amateurish question, but hey..
I've got beocenter 5000 which I've had for a couple of years. The turntable has gradually started losing speed or is erratic, and I'm guessing it needs a new belt. So:
1. How do you remove the platter? It doesn't seem to lift off like most turntables.
2. Any tips on where to get a replacement belt?
Thanks in advance for any help
Dave Farr
France
Posts 2,283
The Beomaster is the amp but which turntable do you have?
The Beogram 5000 TT that is normally with the BM5000 has a platter that simply lifts off.
Depending then on which TT you have will dictate the source for your belt.  Possibly Axel in Germany:
https://www.schallplattennadeln.de/RIEMEN-BELTS/PHONO-RIEMEN-n-Hersteller/A-C/B-O/
Dave.
Thom Chesshyre
United Kingdom
Posts 13
Sorry, I'm being hopeless, will teach me not to send messages late at night.
BeoCENTER, not Beomaster.
Thom Chesshyre
United Kingdom
Posts 13
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Jun 2 2015 10:48 AM
No problem.  I think you need to lift the centre spindle and then lift the platter off - it's in the user manual.
Dave.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jun 2 2015 9:35 PM
The platter lifts right up and off. It may bind a bit, though. The center hub stays.
I can supply correct belts, also for the tapedeck section.
Thom Chesshyre
United Kingdom
Posts 13
Dillen,
Thanks - with added confidence I gave the platter another go and it did indeed come off.  I think it was made difficult by the fact that everything's floating.
I've given the motor spindle and platter spindle a good clean, and as suggested here http://forums.stevehoffman.tv/threads/cleaning-turntable-belts.120339/ boiled the belt for a couple of minutes to reinvigorate it, and also cleaned it, and it seems to have a bit of life left in it.
I will certainly get in touch when it does give out though - how much would you charge for a full set of belts shipped to the UK?
Thanks!
Dillen
Posts 13,191
Dillen replied on Wed, Jun 3 2015 4:41 PM
You have email ...
Page 1 of 1 (8 items) | RSS
