Beomaster 7000
andrew
Sussex UK
Posts 47
andrew Posted: Wed, Jun 3 2015 3:04 PM
Hi. I've just bought a beomaster 7000 - looks to be in good condition and is working. Where can I find n instruction manual for this? Also, will the blink 1000 which I have work with this, or do I need to get another control unit?
Andrew
Ben_S
UK
Posts 631
Ben_S replied on Wed, Jun 3 2015 3:13 PM
Hi there,
Beolink 1000 will work fine. Instruction manuals are available onsite.
As you are a silver member you can access the manual for the BM7000.
Ben
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Jun 3 2015 4:15 PM
To get the most from the 7000, you will need either a Beolink 7000 or maybe a MCP5500 - both these allow programming so you can use the system as a very sophisticated clock radio!
Peter
andrew
Sussex UK
Posts 47
andrew replied on Wed, Jun 3 2015 8:34 PM
Well, I've tried everything I can think of! The begram  70000 cd works fine. The Beomaster seems to work but it simply doesn't respond to the beolink 1000.. Which works well with the system in my other room. Have I bought a dog / an expensive repair job - or am i missing something simple and obvious to everyone brighter than me??!! I can't increase the volume, change from CD to radio etc etc from the beolink 1000. It does it perfectly with my beocenter 8500. ...  The 7000 seems pretty much inert.
leosgonewild
Helsinki, Finland
Posts 2,373
Sounds like it is in a.option 0.
Set it to a.option 1 or 2.
Turn of the unit, on the remote push
Sound
1
Store
Page 1 of 1 (5 items) | RSS
