Hi Beoworld,
I have recently bought a Beomaster 7000 with the beogram cd 7000.
When I play a cd on it, it begins lagging after about 30 - 40 minuets. And when I eject the cd and put it in again it runs well in about 30 - 40 minuets again without problems. And after the minuets it is the same story as above.
Do any of you have an idea of what it could be?
Sincerely
My first suggestion would be to replace capacitors - get a kit from member 'Dillen'. Whilst you're in there, clean and lubricate.
Dave.
Alright, I'll try that. Thank you for your answer.
