It's this type
http://www.beoworld.org/prod_details.asp?pid=326
I purchased the unit off ebay. The light bulbs need replacing for the tuning meter illumination and the stereo indicator. I have found this information from a archived thread.
"Looking at the manual, I noticed that the Stereo bulb was 12v 30mA and the other two were 6v 30mA."
I think the third one mentioned is the scale slider bulb.
Can someone please advise what bulbs I should buy? These are 'wedge' type bulbs as shown here. Is it possible to suggest what I want from this bulb list at RS, then at least I know a supplier?
http://uk.rs-online.com/web/c/lighting/incandescent-light-bulbs/filament-indicator-lamps/?applied-dimensions=4294884489&esid=cl_4294967294,cl_4294958272&m=1&aaaExp=Y&sort-by=Diameter&sort-order=asc&pn=1
Do I really need bulbs rated at two different voltages? Would one type do?
BTW, the printing on the original bulbs is not too clear, but I think it says PH 6/30 on the meter illumination bulb and PH 12/30 on the stereo indication bulb.
Cheers and thanks for any help.
Thank you. Will Dillen see my message or should I contact him somehow?
BTW, I wonder if anyone can help. I have obtained a service manual that only shows the tuning cord fitting and the printed circuits and components. I believe the ferrite rod is missing and wanted to confirm this with diagrams of the physical layout. Can anyone supply me with a physical layout please? If it is missing I'm happy enough for the FM and mp3 amplification only, as the M, L and SW frequencies don't work. Could I obtain a ferrite rod from somewhere?
cheers
Nick
Hi
Many thanks for your help. I now have several bulbs winging their way from Martin in Denmark at very reasonable cost.
