hi everyone,
I was lucky enough to find a nice BeoGram3400, however this one runs on US 117V.
not a huge problem as such - it has no voltage selector but looking at the tabs of the transformer
and the circuit diagram, I wonder if it could be re-wired to set up for 220V using the tabs differently
as per service manual circuit diagram.
can someone perhaps shine some light on this ??
cheers, ALF
forget it folks,
one day I might try and see what happens, in the meantime I am using a travel step-down transformer
for devices not using more than 50Watt, costing the huge amount of $5 incl postage.
Sorry, I didn't see your post until now.Can you tell us the 4-digit type number of your Beogram ?
It is typ 5726
Cheers, ALF
Something like this:
Thanks martin,
That is the procedure I had in mind trying
Thanks for confirming - much appreciated
ALF
