Beogram 4500 turntable tonearm not moving
This post has 26 Replies | 2 Followers
Wandmedia
Posts 16
Wandmedia Posted: Thu, Jun 11 2015 7:02 AM
Decided to play a vinyl only to find the arm not responding to the operation buttons.  Removing the platter i discover there is a white string with a small spring attached idlely laying amongst the other components.  I am assuming this is why there is the lack of movement in the arm.
Any advice as to how to correct or reattach would be greatly appriciated.
Erik
Jason
Redditch Worcestershire
Posts 177
Jason replied on Thu, Jun 11 2015 8:28 AM
There may be a little clip broken on the white plastic tonearm mount that holds the string and spring, a small screw can replace it if it is, a picture of the inside would be helpful
Jason
Posts 177
Jason replied on Thu, Jun 11 2015 8:31 AM
If it does turn out to be that try and locate the tiny piece so it doesn't get lodged in the many cogs, it could cause mayhem when working again
Wandmedia
Posts 16
Wandmedia replied on Fri, Jun 12 2015 8:04 PM
Jason :
Hi Jason ,
Thanks for the response.  i can't see anything broken, here are some images with the platter removed.
Jason
Posts 177
Jason replied on Fri, Jun 12 2015 8:26 PM
Your pictures havn't appeared
Wandmedia
Posts 16
Wandmedia
Posts 16
Wandmedia
Posts 16
Wandmedia
Posts 16
Wandmedia
Posts 16
Wandmedia replied on Fri, Jun 12 2015 8:30 PM
Hope you can see them now.
Jason
Posts 177
Can you take one of the white plastic piece attached to the bottom of the tonearm, it slides along the stainless steel rod, you may need to remove the 2 screws underneath the deck and hinge it up into service position
jason
Jason
Posts 177
Jason replied on Fri, Jun 12 2015 9:04 PM
Sorry if my picture is too big , first pic I've put in beoworld straight off my phone
Wandmedia
Posts 16
I could not see what you referred to but I did see a little white piece of plastic that looked as if it had snapped off from something.
Wandmedia
Posts 16
The white bit of plastic stuck to the silver bar
Wandmedia
Posts 16
another angle
Wandmedia
Posts 16
Another view
Wandmedia
Posts 16
Can't see where it comes from
Jason
Posts 177
Jason replied on Fri, Jun 12 2015 9:20 PM
Compare yours to the picture I added, I'm pretty sure that's your issue and the origin of that tiny piece
regards Jason
Jason
Posts 177
Jason replied on Fri, Jun 12 2015 9:21 PM
Take off and put your stylus safe while your working on it
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Jun 12 2015 9:22 PM
Confirmed, that tiny white hook has snapped off the tonearm carriage where it used to hold the end of the white wire that moves it. A classic fault and relatively easy to fix.
--mika
Wandmedia
Posts 16
This looks like your pic it appears that little piece is broken.
Wandmedia
Posts 16
Wandmedia replied on Fri, Jun 12 2015 9:32 PM
Thanks to everyone who helped diagnosed the problem.
Is this a item I can get spares from B&O?
Jason
Posts 177
Jason replied on Fri, Jun 12 2015 9:40 PM
No longer a spare part, you can improvise with the tiny nut and bolt, it will be working again in no time
regards Jason
Wandmedia
Posts 16
Wandmedia replied on Fri, Jun 12 2015 9:50 PM
OK.
Do you have a plan I could follow to rectify this situation?
Cheers
Jason
Posts 177
Jason replied on Fri, Jun 12 2015 10:22 PM
If you can put a nut on a bolt you can fix it
bolt goes in from underneath and the nut goes on top , the bolt protrudes slightly so the spring and string can hook over it
Wandmedia
Posts 16
Wandmedia replied on Fri, Jun 12 2015 10:36 PM
OK.  Do you have a guide or pic showing how the string is put back in place?
Søren Mexico
Mexico City
Posts 6,411
Wandmedia:
Should be in the service manual, available for silver and gold members
Page 1 of 1 (27 items) | RSS
