Interested in controlling your ML setup with a Raspberry Pi?
This post has 168 Replies | 18 Followers
riverstyx
SouthWest UK
Posts 938
Hi BeoMotion,
Please put me down for one. I don't expect you to give it away though - I am more than happy to contribute a share of the PCB fabrication and component costs along with whatever it costs to post it to me.
Kind Regards,
Martin.
frog
Camberley UK
Posts 624
frog replied on Sat, Oct 10 2015 11:16 AM
duplicate  - site isnt great for editing on an iPad! (or a Mac with Safari either)
frog
Camberley UK
Posts 624
Ink me in too!
frog
Camberley UK
Posts 624
duplicate
frog
Camberley UK
Posts 624
duplicate
frog
Camberley UK
Posts 624
Ink me in too!
BeoMotion
Posts 384
BeoMotion replied on Mon, Oct 12 2015 10:28 AM
@ TWG, riverstyx, frog: great, thanks!
Finally the PCB's arrived today and almost all parts.
Only the power IC's are still in transit.
As soon as they arrive I can assemble the boards.
See the attached picture for a size comparison between the ML board an a RPi.
BR,
BeoMotion.
Fl_ip
Posts 160
Fl_ip replied on Mon, Oct 12 2015 9:16 PM
Please put me on the listSmile
mattb
Posts 1
mattb replied on Fri, Oct 23 2015 7:56 PM
Hi all, I just came across this and read this thread and the technical one. I'm very interested in a PCB to connect to a RPi. In fact, I would take two. The idea I'm having is to connect a Raspberry to the BLC and read Masterlink data. I could then control my Yamaha AV-receiver for Internet Radio and Spotify, the audio is already connected to the BLC line in.
@BeoMotion: you mentioned you have some initial python code to interpret masterlink telegrams. Did you put that on github or somewhere else yet?
kind regards, Matt
sia
Posts 48
sia replied on Fri, Oct 23 2015 8:27 PM
Please count me in too
sia
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Fri, Oct 23 2015 9:45 PM
mattb:
kind regards, Matt
Hi Matt,
Welcome to beoworld and thanks for your interest in this project.
Decoding of the ML protocol is still at a very early stage - once I have an interface to work with and can start injecting telegrams into the ML network it should become easier to make progress on this. So far I have just worked with some sample data that BeoMotion logged whilst performing various actions with the connected equipment.
Nothing is on github yet, but I'll upload a tgz to the technical thread now in case you or anyone else wants to take a look.
Kind Regards,
Martin.
BeoMotion
Posts 384
BeoMotion replied on Sat, Oct 24 2015 9:18 AM
thanks a lot for uploading the perl decoder, riverstyx!
Unfortunately the current ML PCB is not fully functional.
The transmitter part isn't working. I have not that much time at the moment for debugging but I will come back to this.
Also the pinout of the RJ45 connector isn't correct although I have checked everything at least twice.
I'll post the schematics of the non working PCB later this day. Maybe someone can see the problem without wasting a whole day for debugging.
BR,
BeoMotion.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Oct 24 2015 12:13 PM
BeoMotion:
No problem - there's still loads of stuff to figure out, even with the current relatively small data set, and like you I am struggling to find much time to work on this at the moment. I will make some time to carry on with this in due course but by making the code public it gives others the option of contribute if they are able and so inclined. The current 'tree of switch/case statements' is messy but covers all of the TELEGRAM_TYPE, PAYLOAD_TYPE, PAYLOAD_VERSION combinations seen so far (and will flag up any new ones encountered as new telegrams are added to the data set) and thus gives a place to add comments for each as their meaning are determined.
BeoMotion:
Sorry to hear this. It proves you were right to take the decision to limit the first prototype to data only but I know this will be of little comfort right now. I'm happy to work my way through the schematic to see if I can identify anything as sometimes a different set of eyes can save hours - this is often the case with finding bugs in code too as it's easy to repeatedly read what you intended to write rather than what you've actually written!
Kind Regards,
Martin.
BeoMotion
Posts 384
BeoMotion replied on Sat, Oct 24 2015 2:20 PM
riverstyx:
Hi Martin,
yes this would be really great!
I've uploaded the current schematic as a pdf in the technical thread.
Thanks a lot.
BR,
BeoMotion.
steve1977
Posts 911
Unfortunately, I have no capabilities and talent in coding or engineering, so won't be able to help. Having said this, please let me know if you need help with testing. Also, it may be worth to put the financial burden on more shoulders and I am happy to contribute. Others of the beiworld community may follow. OR you even go with kickstarter?
JoDap
Posts 22
JoDap replied on Mon, Nov 2 2015 8:58 PM
I would also take 2, potentially 3. One question, though: do you think it would be possible to communicate with Beolink Wireless as well or is anyone else working on that?
The main reason why I am asking is, because I am also considering a project were I would try to realise something like the LC2 using an Arduino. If Beolink wireless communication is possible, the light controllers wouldn't need their own IR receivers.
Regarding the electronics I am afraid that I can't offer any useful help. But if you need help with designing a casing and making 3D CAD drawings of that, I am happy to contribute and make them accessible for customisation and 3D printing (I'm not a professional, but it wouldn't be the first time I'm doing it).
BeoMotion
Posts 384
Okay, great. Thanks for the feedback.
Yes, I also thought about crowdfunding but I think it is a bit to special.
First thing now is to get the DATA PCB up and running.
Unfortunately I haven't had the time until now for debugging.
Hopefully there will be some hours left for that next weekend.
I'll keep you posted on the progress.
Yes, 3D printed cases would be the way to go on such a small series.
So I'm sure you could help and contribute some nice STL files to the project as soon as the size of the PCB's are final :-)
BR,
BeoMotion.
JoDap
Posts 22
JoDap replied on Tue, Nov 3 2015 10:15 PM
Great, just let me know when you have some more input on that
JoDap
Posts 22
JoDap replied on Tue, Nov 3 2015 10:16 PM
BeoMotion
Posts 384
BeoMotion replied on Thu, Nov 26 2015 12:03 PM
Hi all,
finally I was able to find some time to hook up a scope and do some investigations.
The ML transmitting part is perfectly working, which are indeed very good news. :-)
The level shifter was the problem.
There are also some other minor design changes to do and then I will send out a second prototyping PCB for manufacturing.
Will keep you posted.
BR,
BeoMotion.
steve1977
Posts 911
steve1977 replied on Sat, Nov 28 2015 3:28 PM
This is great news. Thanks and well done!
steve1977
Posts 911
steve1977 replied on Wed, Dec 23 2015 7:58 PM
Has the new PCB arrived and any update for us?
steve1977
Posts 911
Has there been any progress in the background and anything I can be helpful with?
Espen
Posts 9
Silver Member
Espen replied on Tue, Mar 1 2016 12:18 PM
Just pulling this one up in hope for any news :)
MJBeo
Netherlands
Posts 270
MJBeo replied on Tue, Apr 5 2016 2:36 PM
Espen:
Same here! I am trying to get the Lintronic box to work over my MCL system, and I want to connect it also to my Pi that is already sitting next to my beovision as a Kodi media center. But it is not really working well for me so to feed the ML/MCL directly into the pi and vice versa is more and more favorable!
Thanks for all the work done so far
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
BeoMotion
Posts 384
BeoMotion replied on Tue, Apr 5 2016 10:17 PM
Hi all,
sorry for my little longer absence here.
For some strange reasons I didn't receive any "new post notification" mails from beoworld and I only randomly look into the active topics.
The current project status is still that we can successfully receive and transmit data from and to the ML data bus.
The first PCB had problems with wrong ML RJ45 pin connections and a very difficult to solder negative DCDC converter.
At the moment my problem is that I'm missing some time for continuing this project.
Good news is that currently I am working hard on a different project which could be easily combined with the final ML PCB and make an even better solution in the end.
As some of you might know I never was really a friend of all that Raspberry Pi stuff...
So when I have the time to continue the work on the ML PCB chances are good that there will be an exclusive connector for my own single-board-computer instead of generic pin headers. More infos on this and some words on why I think using a not a Pi is better to come soon...
Of course the idea is still to make the ML PCB and SW fully open source with all PCB design files available. So that people are able to tweak the design and the SW for their own needs.
BR,
BeoMotion.
_beast_
Posts 1
_beast_ replied on Sun, Apr 10 2016 5:14 PM
Hello BeoMotion,
I'm also interested in two or three pcbs.
How do you connect them to the RPi? flying wires?
kind regards
_beast_
BeoMotion
Posts 384
BeoMotion replied on Thu, Apr 21 2016 8:19 AM
yes, the initial plan was to connect it via single jumper cables.
The new version I have in mind can be connected using a single FPC cable.
I will come back in about 2 to 3 weeks with more news :-)
BR,
BeoMotion.
TWG
Posts 1,672
TWG replied on Thu, Apr 21 2016 8:48 AM
When it's more flexible using single jumper cables, please stay with them. :-)
I'm REALLY happy when we have a small simple box that can pass "light" and "control" infrared commands onto the ML bus as it will be a GREAT benefit for the home automation fun for places where a B&O speaker or audio system would be out of place.
I'm excited to test and see the final product!
If you need support please let us know!
BeoMotion
Posts 384
BeoMotion replied on Thu, Apr 21 2016 11:03 AM
At the moment I'm discovering that some people have difficulties with jumper cables.
It is easily possible to count pin headers in the wrong direction, swapping colors, ...
For a different project I'm currently engineering a single-board-computer from scratch.
It has a nice size, native support for ethernet, WiFi, BT and some other nice things.
It also comes with a special audio connector featuring two serial ports and two completely independent audio interfaces.
This is excellent for building a ML bridge or anything else that needs two independent ML sockets.
Due to the demands of the other project this special SBC comes with small pitch FPC connectors.
This is the reason I have in mind to make the ML PCB plug-n-play with that machine.
BR,
BeoMotion.
Michael
Sweden
Posts 2,578
Michael replied on Thu, Apr 21 2016 12:12 PM
Can this be used for NL conversion as well?
BeoMotion
Posts 384
BeoMotion replied on Thu, Apr 21 2016 12:53 PM
Michael:
Why not? :-)
Would require some reverse engineering on the NL protocol but seen from the hardware side there is nothing that could prevent this function.
I think at the moment the NL protocol is plaintext and you can easily listen and learn from an existing setup.
As long as they don't start to encrypt it this is a manageable tasks.
Michael
Sweden
Posts 2,578
Michael replied on Thu, Apr 21 2016 1:30 PM
BeoMotion:
Why not? :-)
That is interesting. I just have a BS9000 still, that is ML so perhaps I should just get rid of it, but it seems like a fun project anyway, and if it could communicate with NL perhaps it could be integrated with other stuff as Hue lights?
BeoMotion
Posts 384
BeoMotion replied on Thu, Apr 21 2016 5:08 PM
Michael:
Yes, of course.
But remember that there needs a lot of SW work to done before we we can even think of such a solution.
First thing is to get the ML communication on the SW side working reliably.
Once this is done interaction with IP based services like Hue or NL is just a matter of how many people are willing to spend some free time on this topic.
kay81290
Vaassen, Netherlands
Posts 16
kay81290 replied on Tue, May 17 2016 9:45 AM
This is a really interesting project, I am going to follow this one.
Also I am interested in one PCB with audio injection, and one PCB without audio injection.
I am running Raspberry Pi 3 Model B's at the moment.
BeoVision 4-65 - BeoSystem 3 - BeoSystem 5500 - BeoVox Redline 60.2 - BeoVox Redline 45 - Beolab Penta MKIII - BeoRemote One  - Beo4 - Master Control Panel 5500 - LC2 - PUC Sources
MJBeo
Netherlands
Posts 270
MJBeo replied on Tue, Aug 8 2017 4:59 PM
Is this still project still in motion? I am still interested!
kai
Posts 362
kai replied on Tue, Aug 8 2017 5:03 PM
I was going to ask the same thing
bjn
Posts 16
bjn replied on Wed, Dec 27 2017 6:17 PM
For a long time I observe this posts with ML communication. if possible I would contribute something.
Simple boards for sending and receiving would be great.
What I did not understand, where can you look at the technical details from your project?
Bruno
bjn
Posts 16
bjn replied on Sat, Jan 13 2018 7:59 PM
This topic is dead??
mczac
Posts 49
mczac replied on Sun, Jan 14 2018 10:57 AM
I have some plans to reverse engineer ML.
I am building a test system with few ML products  and RS485 transceivers which I am not afraid to burn, I am then planing to record and interpret RS485 bus communication. Once timing and data structure is figured out, I am planning to build a dictionary of control commands and device addressing structure as per RS485 Master/Multiple Slaves addressing.
Once this is complete, possibilities are endless. Firstly, any NL products could be integrated into existing ML network, also major limitations of ML could be lifted, having multiple master like I do, masters can be dynamically allocated based on the desired audio workflow with sources and outputs. And finally, all devices could be controlled via home.app on iPhone and for more refine controls via say single web.page. That would leave no need to use BLGW and NL/ML contverters and rather have automation based on home kit and google home or Alexa.
If any of you is willing to contribute, I will be grateful if you can send anything that you have obtained so far with regard decyphering ML protocol, data structure : speed, parity bits, MSB/LSB order. Thanks.
Page 4 of 5 (169 items) < Previous 1 2 3 4 5 Next > | RSS
