Hello,
I placed the same question in the german section before, without any answers, so I try again here.
I use a 1611 converter with my BS3000 as input for the TV sound, which works fine.
I'm thinking of get another one as 3rd "AUX input" for my BS. So my question is:
How will the system behave in that case (two 1611 on the masterlink)?
Now, when I press the "TV" button, the converter opens the datalink port. When using two of them, will both open their ports, or does the second one will recognise, that It's not "alone" on the ML-bus? Will it react to other commands in this case (e.g. V.MEM)?
Would be nice to get the answer here, before buying a second converter.
Thanks in advance,
Kolja
