Added beolink active
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Fri, Jun 19 2015 7:39 PM
Hello all
I have a party at 8pm this evening and I just bought a beolink active from the guys at lifestyle, thank you
Any idea how to get the beolink gateway to see it.
I tried capture but it does not see it.
Cheers all
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
BeoMegaMan
Posts 601
You need a current master somewhere in the mix as well as an IR eye attached to the Active Kit. You will have to give a command to the active kit while the gateway is in ML capture mode so it can be identified on the ML side. After that you can then take the IR eye off and run the active kit completely through the gateway.
Ah, you know... A little B&O here, a little there
Seanie_230
UK
Posts 2,278
Found t thank you.
It did not capture by pressing the IR it needed to be on or off via the remote.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (3 items) | RSS
